Sponsored by: CARiD
Im 15 and i bought a 1987 Toyota 4x4 (See pic)
Old Jun 24, 2008 | 02:01 PM
driveithard's Avatar
what can i do to my truck that don't cost much for performance my truck is a 87' 4x4 22re i think with a 5 speed standard thanks a pile alex
Old Jun 24, 2008 | 02:16 PM
Jay351's Avatar
Congrats on the purchase! I got mine when I was 16
Not to much to do in terms of performance on the cheap on these engines but...
ISR mod (search it )
tune up
higher flow airfilter will help a LITTLE in the power department, but at the cost of less filtration. (I stick with oem paper filters)
Make sure your gearing in your diffs is suited to the tire size you are running.
Old Jun 24, 2008 | 03:52 PM
abecedarian's Avatar
there are some decent tri-y headers available for a few bills
replace the stock exhaust (and possibly the cat with a high-flow) with 2 1/4" pipe and better muffler such as one of the magnaflow or flowmaster units (with or without a header)
Old Jun 25, 2008 | 10:39 AM
lotalucas's Avatar
Hey. I'm dirt poor and i do my best too. I bought a old school cherry bomb for 30 bucks, I'm custom building a cold air intake. Saves a lot of money. If i were to try and buy an already built intake for my truck it would cost 250 but since i'm building it myself maybe 30 bucks max. If you want to do a lift I would say start out with a body lift. They don't do anything but get you higher off the ground so you can add bigger tires but their a start when you don't have a lot of money. if you want bigger tires you can do two things. You could try and buy new ones i recomend procomp. Not neccesarilly because their the best but because you can get a full set for under 700 new which is still a lot of money to me but their pretty nice tires. Or you could be patient and wait tell you see some show up used in the local paper. You could get a pretty decent pair for next to nothing. it make take a while though. If you have access to a welder than you can do a ton of stuff. Just keep your mind open to idea's and you'll end up with a pretty nice rig for pretty cheap.
Old Jun 25, 2008 | 10:44 AM
dirtoyboy's Avatar
22re and performance dont belong in the same category....
Save your money to make the truck reliable (in stock form) and upgrade the more important things that will get you down the trail
Oh, and congratulations on your purchase.......Welcome to Toyota
Old Jun 25, 2008 | 12:23 PM
i found a exaust header on ebay for 110 + shipping is that good
Old Jun 25, 2008 | 12:45 PM
astyles's Avatar
I would recommend you read these forums and see what other people do and decide exactly what you are looking for. Remember that it is better to have a reliable truck than a pretty piece of poo. You've chosen Toyota so you are already headed down the right path. If you treat your truck right and take care of it it will take care of you.
Since this is your first vehicle (I assume), you might learn how to work on your truck. It will be easy to do since Toyota Trucks are lifted more than most vehicles stock and you can slide right underneath it to change the oil...etc.
First off, do you know any history about the truck? How does the truck run?
Old Jun 25, 2008 | 12:49 PM
Jay351's Avatar
What kind of header is it? Depending on the brand and condition of it, it sounds like a pretty good deal. How much is shipping?
Old Jun 25, 2008 | 12:59 PM
olharleyman's Avatar
I HAVE A 3"BODY LIFT WITH GAP GAURDS NEVER INSTALLED FOR THAT TRUCK IF YOU IT FOR 100 PLUS SHIPPING
I ALSO HAVE A SET OF REAR TOYOTA 3" SPRINGS I WILL LET YA HAVE FOR 100 AND SHIPPING
I HAVE THE FRONT GRILL PIECE IN NEAR PERFECT SHAPE I WILL LET GO FOR 50 OR IF YOU SAY WANT THE SPRINGS AND BODY LIFT I WILL THROUGHT IT IN FOR FREE
AND IF YOU FILL REAL BRAVE I WILL BE SELLING MY BFG KO'S 35 X 12.5 X 15 WITH 10-12/32'S ON ALL FOR FOR 400 SHIPPING
IF YOUR INTERESTED LET ME KNOW ALSO WHERE ARE YOU LOCATED?
Old Jun 25, 2008 | 01:19 PM
shipping is 50$ out of alabama it not brand name but its brand new 2 1/2 inch pipe
Old Jun 25, 2008 | 01:20 PM
ya that sound great let me see what i have left after the summer is over and ill get back to ya thanks alex
Old Jun 25, 2008 | 01:30 PM
Fink's Avatar
Moved to Newbie Tech Section.
Do a search on here in the forum dedicated to your year model rig, there is a TON of info out there. There are a lot of people on here with similar rigs and I'm sure they are looking for the same info...a lot of them have already found it I'm sure.
Good luck and welcome to YotaTech!
Fink
Old Jun 25, 2008 | 01:31 PM
toyNG's Avatar
I'm pretty new to this forum also. My best advice is to just read up on this forum as much as you can. Some of the guys on here know a ton and everyone is super helpful. Also, the factory service manual and/or Haynes manual will teach you lots.
Old Jun 25, 2008 | 01:33 PM
ya man thanks i love this site i cant fid out what a IRS mod is tho its a air flow somthing
and also what year did toyota switch to EFI
Old Jun 25, 2008 | 01:38 PM
Fink's Avatar
FAQ's are a great place to start - some of the pics may be dead but the core info is still there.
It is actually the ISR mod..."Intake Silencer Removal" mod.
If you do a Search for "ISR mod" you will get a TON of hits.
A lot of people have done it with great success although to be honest, I haven't heard much about it being done with the 22r. I personally like the deckplate mod more. Deckplate mod is where you cut a 4" (some do bigger) hole in your airbox and put a marine deckplate (allows the ability for it to be open or closed) in. Clear your ECU (remove the EFI fuse for a little while) and you're set. I noticed a performance gain right away.
Good luck in your quest!
Fink
Old Jun 25, 2008 | 02:00 PM
dropzone's Avatar
Fossilized
Do a search on here in the forum dedicated to your year model rig, there is a TON of info out there. 1st gens have a huge following and a lot of people are trying to do the same thing you are to their 1st gens.
Fink
Good advice, however the '87 makes it a 2nd Gen 4x4 Toyota (84-88). First gens 4x4 are 79-83
Old Jun 25, 2008 | 02:05 PM
Fink's Avatar
I was thinking 4Runner...you caught me.
Fink
Old Jun 25, 2008 | 04:30 PM
rowdy235's Avatar
As far as when toyota switched to EFI, EFI was first available in 85, however, the 22r (carb) was still available up until 89, mostly in base trucks. I've heard it was available until 95 in commercial models. Pop the hood, if its a carb, you'll see a large circular object on top of the engine, if its EFI, it'll say so on the left (as viewed from front) side of the engine. Of course, if the label is still intact, you'll see either a 22r (carb) or 22re (EFI) sticker on the front.
Hope this helps.
Old Jun 25, 2008 | 05:24 PM
ya well i havent picked it up yet so ill look when i get it i hape it carbed!
Old Jun 25, 2008 | 05:44 PM
hey man not to keep bother ya but what do ya think is a fair price fer a front fender?
