ignition prombles
ignition prombles
hey guys i need to know if anyone is has ever had ignition prombels where when it runs for awhile and warms up and you drive it cuts out and dies but after you let it set and cool down it will start up again would a 80 have a ignition module on it and where would she be at im new to toyotas i was thinking it was in the distributor it is crabureted if you guys have any clue thanks it has a 86 enigne in it thanks
What are prombles ?.
When the problem your having happens does your truck act like its running out of gas ?, if so, when was the last time you replaced the fuel filter ?, also check the gas cap and make sure its a vented gas cap, if it not its the wrong gas cap.
i have two new filters and they are clean and clear and the gas cap is the org oneand yes it acts likes it running out of gas it has a brand new webbar carb on it and brand new fuel pump and its getting good flow at idol
I have had bad coils do exactly that when warm... search on here for the fsm, then check the coil per fsm instructions... if it comes back good, get urself a spray bottle with water, start truck, and spray coil... see if it changes the idle, or makes it stall. if not...I'd say u can rule it out.
zombie_barbarossa
Oct 2, 2015 10:54 PM
