Sponsored by: CARiD
Ifs Vs Sfa
Old Aug 6, 2008 | 09:10 AM
ILLINOISYOTADAWG's Avatar
i have had both an 82' with a 5" lift and an 86' xcab and like everyone has said the 82 would go places the 86' couldn't but if you learn how to drive what you got then you will be supprized just what a yota will do.and yes the 82'with sfa sucks on road
Old Aug 6, 2008 | 09:16 AM
dirtoyboy's Avatar
Originally Posted by stormin94
Solid front axles are also strong, and durable, and mechanically simpler. However, they are prone to rollovers more than an IFS.
Please explain this!
Old Aug 6, 2008 | 10:03 AM
waskillywabbit's Avatar
Learn to search newbie and try to have an original thought!
I have yet to see any competition or serious rockcrawler be IFS, but it really depends on the environment you wheel.
SFA = dedicated trail rig
IFS = streetable wheeler
I love my IFS 08 Tundra but I wouldn't take it wheeling.
Stop letting Jeep owners ask questions. Even in the newbie section this thread is stupid.
Old Aug 6, 2008 | 10:26 AM
tc's Avatar
tc
Actually, there's a couple IFS rigs in XRRA now
Old Aug 6, 2008 | 10:29 AM
  #25
dirtoyboy's Avatar
really? I was just at an XRRA race a couple weeks ago and I didnt see any
Old Aug 6, 2008 | 10:31 AM
  #26
tc's Avatar
tc
I'll have to find the thread on co4x4 ...
Old Aug 6, 2008 | 11:28 AM
  #27
904_runner's Avatar
In the current 4wdtoyotaowner there is a piece on ifs Vs. the hammers.
Old Aug 6, 2008 | 06:23 PM
  #28
89silverpu's Avatar
And how they took a bunch of ifs tacos and fjs over them and they did very well
Old Aug 9, 2008 | 12:30 AM
  #29
stormin94's Avatar
If you're asking me to explain why IFS results in fewer rollovers than SFA, I can't, since I'm not a scientist, but I'm sure there are a few on this board who can. That's just one of those things that just happens, like how jello works.
Old Aug 9, 2008 | 09:17 AM
  #30
tc's Avatar
tc
Yep, more SFA rigs have rolled than IFS ... but a lot of it is coincidental. The guys who have needed to SAS are the ones running extreme trails where rollovers happen.
Kinda like people break 5.71's ... well, they have big tires, and usually they have big tires because they need them for the extreme trails they run ... so is it because 5.71's are weak or because they are applying more force?
Old Aug 9, 2008 | 07:49 PM
  #31
algranger's Avatar
Originally Posted by BLKNBLU
Yeah in 240k miles broken a arm, zero. bad ball joints, zero. bad cv's, zero. torn cv boots, 4 or 5. bent a arms or crossmembers, zero. I did replace the BJ's when I put in spacers about a year or two ago, but only because I was already in there.
i had quite a different experience.. guess it depends on how and how much you wheel it
Old Aug 9, 2008 | 08:22 PM
  #32
BLKNBLU's Avatar
Yeah I guess I probably don't wheel it hard enough.
Old Aug 10, 2008 | 09:06 AM
  #33
dirtoyboy's Avatar
Well then don't make blanket statements like that unless you have some type of fact (or even an opinion of your own) to back it up....thats like the blind leading the blind
Old Aug 10, 2008 | 09:45 AM
  #34
algranger's Avatar
i dont see it off the ground. going over big rocks is one thing rallying it is different, like i said earlier it depends on what your looking for
Old Aug 10, 2008 | 09:51 AM
  #35
tc's Avatar
tc
So now you're comparing jumping a stock IFS truck to a custom suspension SAS rig?
Why don't they use SFA on Baja rigs then? Because long travel IFS is better for that stuff ...
Old Aug 10, 2008 | 09:55 AM
  #36
algranger's Avatar
my straight axle front end is stock and it has taken more jumps than the ifs with no problem my point is stock sfa is much stronger, i know ifs is better for prerunnin and stuff
Old Aug 10, 2008 | 10:03 AM
  #37
BLKNBLU's Avatar
Do the baja rigs even have 4wd? I ask because I don't know much about it. I was under the impression that many/most of those vehicles were 2wd with all the emphasis on suspension travel. In which case the whole comparison becomes even more obtuse.
Old Aug 10, 2008 | 10:41 AM
  #38
EWAYota's Avatar
I'm not that knowledgable with Baja rigs, but I'm sure there are classes with 4 wheel drives. If memory serves me correctly, Pirate had a team run it in a Cherokee. Regardless, I do know that CORR runs 2 and 4 wheel drives, and they run IFS.
Old Aug 10, 2008 | 11:07 AM
  #39
overdrive00's Avatar
like it's already been stated... each have there own pro's and con's
i must say i like my SFA... i've gone 150km/h with my 35's and had no wobble's... although this was before my accident and with only 70,000 km on my truck and the lift only being a year old.
a friend of mine has an 89' IFS pick up with over 300,000km's... the only thing i don't like about his ride quality, is that he has 4" lift blocks with the stock springs in the rear, having a braket lift up front, seems to be very comparable... my truck having lift springs all around i find ride's better... he also agree's. but that's the rear end and not the front.
and as for 3rd gen runners. you get a nicer interior. if you get a limited you get a rear e-locker. i know 97limited and his 4runner with the sonoran lift and 33's ride's better than stock. although he has custom sway bar end links and poly bushings. for a lifted toy i must say that's the nicest ride i've been in with a lift. 160km/h on the sea to sky highway with about 150 pounds of mountain bikes on his hitch mounted bike rack. takes the corners well. but not many people drive their trucks that fast and hard.
really it depends on what you really want to do with your rig. hard core wheeling/rock crawling. then you may want to go with sfa. not to say an ifs can't handle some rocks cuz they can i've seen it first hand.
overdrive
Old Aug 10, 2008 | 07:13 PM
  #40
stormin94's Avatar
It's a fact, but don't just take my word for it:
http://www.offroaders.com/info/tech-...ky-terrain.htm
