Sponsored by: CARiD
I over tightened rear brake ajuster
Old Sep 30, 2011 | 02:11 PM
4xfloored's Avatar
While attempting to adjust the rear brakes on my 00 T4R I some how over tightened the left rear to the point the it has to much drag... can some one tell me how to take some of the pressure off... it seams like on the little spur wheel i can only get to rotate to tighten only.. thank you in advance
Old Sep 30, 2011 | 02:29 PM
wyoming9's Avatar
Smile
You use another tool of your choice to hold the arm away from the adjuster and of course turn in the opposite direction .
It is a trick to get the feel for adjusting brakes it will come with time.
Good luck
Old Sep 30, 2011 | 05:58 PM
Lawn Dart's Avatar
Pull the spring away with a small screwdriver, then adjust it away. I usually adjust it until the wheel won't spin and back it off one.
Old Oct 1, 2011 | 06:30 AM
GuitarMike's Avatar
Like they said.
I'm having the same problem, sucking up the will to go back and finish it....Man, don't you HATE those adjusters?? You can't even SEE them to work on 'em! Get the FSM online, have a look at their construction....you need to push the little forked arm on the inside towards the drum (from the underside of the vehicle), while you turn the star wheel the opposite way from 'that which makes it click'. Not a very good description... Total PITA.
Old Oct 1, 2011 | 08:31 AM
4xfloored's Avatar
Good luck
got it ..just needed a flash light to see it
thank you
Old Oct 1, 2011 | 08:33 AM
4xfloored's Avatar
thanks again to all who replied with help
Old Oct 1, 2011 | 01:57 PM
wyoming9's Avatar
Smile
Your welcome!!
Glad you got it fixed
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
rondogracing
Jul 14, 2015 07:00 PM
87turboPA
Jul 9, 2015 05:58 AM
