I need help!!! No power 89 22re pickup
Old 10-24-2009, 04:53 AM
tuffyota90's Avatar
Exclamation I need help!!! No power 89 22re pickup
My 89 toyota 4x4 22re last night i was messing around in the snow spun out then drove for about a mile then lost all low end power??? It will not get up in speed less if your foot is to the floor.
Old 10-28-2009, 06:37 PM
craigory1983's Avatar
check your air flow meter mine had a similar issue and the flap was totally loose inside there should be resistance to open. also the o2 sensor could be causing your issue after i replaced my airflow meter the truck was sluggish in midrange i unplugged the sensor and it ran great so i replaced the sensor and the truck drives great
Old 11-06-2009, 06:52 PM
Ron Helmuth's Avatar
if not air restriction coming in then fuel restriction. Fuel filter is my best guess from your description of the symptoms. Run a can or two of fuel cleaner through it just for kicks and see if you notice any help.
No codes mentioned(?) cat smelling? any weird exhaust or gas odor?
Old 11-06-2009, 08:34 PM
Kiroshu's Avatar
Any lights on? Trouble Codes? Is there a check engine light on while this was happening.. if so i suspect airflow... check resistance of air flow meter and make sure its in spec... if any of it is not in spec it needs replacing... check for fuel... spark....
DacodaYota
09-02-2015 02:13 PM
Sandman
07-23-2015 08:15 PM
puddlepirate
06-30-2015 05:08 PM
1badyota350
06-28-2015 06:50 AM
nyk08trx
06-18-2015 09:01 PM
Quick Reply: I need help!!! No power 89 22re pickup
