Sponsored by: CARiD
i hate to ask but what is high pinion
Old Nov 19, 2008 | 12:53 PM
SR5's Avatar
SR5
i know comes with ring and pinion gears, but what is it
Old Nov 19, 2008 | 12:55 PM
akaphilly's Avatar
google...
study http://home.4x4wire.com/erik/diffs/
Old Nov 19, 2008 | 01:04 PM
tc's Avatar
tc
It's a high pinion
Seriously, with helical gears, the pinion can't be right at the centerline of the ring gear. Low pinion puts it below the centerline, high pinion puts it above the centerline. Obviously, HP has better ground clearance and usually better driveline angles.
High pinion gearsets are approx 30% stronger in the FRONT axle than low pinion because the teeth engage on the drive side instead of the coast side. HP diffs are WEAKER in rear applications for the same reason.
Old Nov 19, 2008 | 01:10 PM
SR5's Avatar
SR5
thancks tc
and akaphilly i did google first, and i couldnt get a straight awnser
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
klavender1
Aug 15, 2015 01:51 PM
trailgoat
Aug 13, 2015 05:54 PM
kirkrunner
Jul 27, 2015 07:59 PM
