Sponsored by: CARiD
High idle...constant...charge light and e brake light came on at the same time
Old Jan 5, 2017 | 11:55 AM
1986yodaPU's Avatar
Have an 86 PU 4 speed 22r....when cold it would have a high idle until the carb warmed up and then pumping the gas would drop it to a smooth idle. Two days ago the end brake dash light and charge light were coming on intermittently...now on all the time and the truck is idling at a stand still around 2k rpm. Remand carb installed roughly six months ago...passed smog with flying colors..of course I am out of town when this happens. Through reading I have seen the AAP...fuel cut off solenoid...and vacuum lines. Replaced all vacuum lines when I did the carb.. and tips on a direction I should go? Thanks.
Old Jan 5, 2017 | 11:39 PM
wyoming9's Avatar
Red face
Trouble Shoot and repair your charging System Problem.
That might cure your High idle issue
Charge your battery with a battery charger
Old Jan 6, 2017 | 10:39 PM
KYLEFOO's Avatar
That light combo indicates a problem with the alternator. I think it's the same whether the system is overcharging or undercharging. Put a multimeter on the battery while the engine is running to figure out which. Overcharging, replace the voltage regulator on the alternator. Undercharging, replace the brushes.
Old Jan 6, 2017 | 10:44 PM
Terrys87's Avatar
The lights are the common signs of a failing alternator like Kylefoo mentioned.
