Sponsored by: CARiD
Hi-Lift Extreme... Is it worth it?
Old May 19, 2006 | 01:10 PM
AH64ID's Avatar
Originally Posted by tc
What a PITA!
Still better than monkeying with a stock jack in the mud or snow... and much easier than replacing your bumper when you f it up jacking off of it.
Old May 19, 2006 | 05:09 PM
tc's Avatar
tc
Maybe, but a lot harder than installing sliders!
For a rear tire, you could use the trailer hitch and lift both tires...
Old May 19, 2006 | 10:04 PM
Robinhood150's Avatar
The stock jack and a piece of wood seem like a better solution for the original poster.
I've tried that when I first got my hilift, very unstable and I highly discourage it.
Old May 20, 2006 | 12:24 AM
rocket's Avatar
Originally Posted by waskillywabbit
Get a plain ole Hi-Lift and use the extra money to get a slider adapter.
X2!
Originally Posted by Robinhood150
You mean the tire hooks that hook to the tire and lift the truck? How does that work if you want to change that tire?
Good point. It wont work!
Even though i sometimes do crazy things with a floor jack, i wouldn't recommend using a Hi-Lift like that on the trail...especially to someone thats never used one.
Agreed for the following reasons...
'00 4Runner SR5 4WD -- ARB BUMPER -- CROSS DRILLED ROTORS -- DUELER REVOS
noodle, IMO theres definitely no need for a 60". I believe a 48" would suit you just fine and even thats questionable based on your lift, tire size, other mods (sliders), and what type of wheeling you do...
Old May 20, 2006 | 07:13 AM
  #25
Nic's Avatar
Nic
Check out Tractor Supply - best prices I've seen.
I bought a 48" one at Tractor Supply-was about $50.00 before tax if I remember right.
Old May 23, 2006 | 12:25 PM
  #26
noodle's Avatar
Rocket,
I have actually added "The 3rd Gen Suspension" by Bamachem Downey rear spring version. So I'm up about 2" now. Most wheeling is moderate at best, currently.
Thank you everyone for all your suggestions so far.
Old May 28, 2006 | 07:45 AM
  #27
BruceTS's Avatar
Originally Posted by noodle
All they did was spruce up a few things on a standard cast version...besided I perfer the Jackmate over their Winch-Clamp-Spreader Attachment...
IntoTheVoid
Oct 24, 2015 04:54 PM
I8URSVT
Oct 5, 2015 05:42 PM
sonorn67
Sep 19, 2015 05:39 PM
kcaudill
Sep 11, 2015 02:49 PM
