Sponsored by: CARiD
Heater issue
Old Sep 25, 2013 | 01:23 PM
Bruinpilot's Avatar
Heater issue
I blew the little heater hose today, the small one from the control valve to the firewall. I noticed that there was pressure (coolant squirting out) despite my heater being selected to off. Is this normal or is this indicative of a problem? Thanks.
Old Sep 25, 2013 | 02:01 PM
Tbrown0102's Avatar
Not sure man. Good luck!
Old Sep 25, 2013 | 02:22 PM
Murcielago's Avatar
That's normal. Both sides of your heater are connected to the cooling system, which operates under pressure. When your heater is turned off, the coolant doesn't flow through the heater core, but it is still under the same pressure as the entire cooling system. So if you blow a hose downstream of the heater shutoff valve, coolant will flow backward and squirt out of the hole.
You should get that fixed ASAP, as otherwise you'll lose all your coolant and ruin your engine.
Old Sep 25, 2013 | 04:54 PM
Bruinpilot's Avatar
Thanks Murcielago. I'm glad to here its normal. I only lost a pint or so of coolant and I have it parked now until I can get the hose. It hasn't overheated so I don't think it should be a problem at this point. Anyways thanks for the good info. I wasn't sure if both sides of the valve were supposed to be under pressure with the heater off. Now I know! Thanks.
the1998sr5
15
Jul 14, 2020 08:35 PM
mussy01
Dec 13, 2016 08:20 PM
94 Newbie
Aug 6, 2015 10:33 AM
Bucksnuff
Jul 31, 2015 07:09 AM
