Head gasket question
Ok I just added a new cam to my truck . Well I had to remove the head bolts to switch the cam out. So when I removed the head bolts I started to lose antifreeze. So i put everything together hoping everything would be ok. But I found oil in the antifreeze.... So on replacing the head gasket do I still have to send the head out to be resurfaced? Just wondering.. Thanx
If you ever do a cam change with the head on again, drain the coolant first.
The head gasket is usually stuck on and the weight of the intake and exhaust help hold the head down. Plus you still have the small bolt under the dizzy drive gear in.
I still use some spacers and stick the head bolts back in to hold it down so it doesn't get knocked loose.
Not the recommended way to change a cam but, not everybody wants to pull the head to do it.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
