Sponsored by: CARiD
which gears are best
Old Dec 2, 2009 | 07:58 PM
Dennis140's Avatar
Originally Posted by 93YotaMonster
if you do get the 4.56s you will get better gas millage with the 31's but if you go to a 33, your going to be back were you started, so if i was you i would go with 5.29's for the 33's at the least 4.88's do to the automatics extremely high over drive
k i'll take that advice thanks
Old Dec 2, 2009 | 08:01 PM
93YotaMonster's Avatar
i wasn't trying to bust your bubble, i hope that helps you
Old Dec 2, 2009 | 08:12 PM
Dennis140's Avatar
it does alot well except for getting 4.88 or 5.29 i just know that 3.90 are killing my motor and trans
Old Dec 3, 2009 | 03:42 AM
well even if you dont gane much, go ahead and try to find a used set of 4.56 gears. and wen you go to move up to a bigger tire just save a little extra cash for some gears.
Old Dec 3, 2009 | 07:36 AM
  #25
Dennis140's Avatar
yea planning on that lol
Old Dec 3, 2009 | 05:46 PM
  #26
brian2sun's Avatar
My $.02 - gear up to the tire you're going to run in the future. I wouldn't want to have to re-gear all over again. That would be more expensive in the long run, and 4.56s w/ 33s wouldn't be much different than 3.90s and 31s. If you're regearing because you're sick of not having enough power, you're defeating your purpose with 33s and 4.56s.
Here are your options IMO:
1) Regear w/ used 4.56s and stay w/ 31s forever... or
2) Get 4.88s and 33s.
Old Dec 3, 2009 | 06:30 PM
  #27
Dennis140's Avatar
point taken prob is i can't just buy a 4.88 third member i will have to buy a whole rear axle lol i just found the third members a 4.88 and 4.56 now i guess i need to find a 4.88 housing
Old Dec 3, 2009 | 06:36 PM
  #28
fork's Avatar
you could probably find a 4.88 third in a junkyard. i'm not sure what youre saying about needing a housing/full axle
i had a 94 v6 auto...
4.88s and 31s was doggish. i slapped in 5.71s for fun and it didn't do a lick of good. wanna know what did? trading it for something else :X
my $0.01
Old Dec 3, 2009 | 06:45 PM
  #29
Dennis140's Avatar
my $0.01
4.88 gears have their own axle housing
Old Dec 3, 2009 | 08:07 PM
  #30
brian2sun's Avatar
I believe the stock 4.88 diffs can't be regeared like 93yotamonster said, but it really doesn't matter because you aren't going to find a stock 4.88 diff anyways because they are rare.
What I'm suggesting is you can buy some 4.88 ring and pinions and regear your existing diffs. Or, buy the 3rds w/ 4.88s (or whatever ratio you want) already installed from a place like eastcoastgearsupply.com. This shop is high quality and their prices are low because you send them your old 3rds back after you get your new ones. Plus you can get lockers also pre-installed in the 3rds for great prices (highly recommend).
Your other choice of course is to swap in used 4.56 3rds. But those aren't exactly plentiful either. And like I said before, if you go to 33s you're going straight back to where you were - bogging down.
Old Dec 3, 2009 | 08:34 PM
  #31
fork's Avatar
differential housing yes, full rear axle no
Old Dec 4, 2009 | 03:37 AM
  #32
Zelephant's Avatar
I don't want to threadjack or anything but while we're on the topic, I'd like something clarified. Can 4:10 diffs be regeared with 4:88 ring and pinion sets, or are there compatibility issues?
Old Dec 4, 2009 | 03:45 AM
  #33
yes they can be regeard to 4.88's. the only diffs that cannot be regeard are the factory 4.88's. and i think some of the older 2wd like early 70's cant cause the older housings want exept that size gear. please correct me if im wrong
Old Dec 4, 2009 | 06:05 AM
  #34
Zelephant's Avatar
That's good. When I register my rig, I'll be running 265s (32"?) with the factory 4:10 diffs and an auto. 4:88s are high on my list of upgrades.
Old Dec 4, 2009 | 06:50 PM
  #35
if i was you i would go ahead and gear to 5.29, because some auto trucks came factory with 4.88's if it came with 31/1050/15's. your just going to wast your money if you run 32's and 4.88's with an auto
Old Dec 6, 2009 | 04:41 PM
  #36
Zelephant's Avatar
It didn't come with 31s, it came with the stupid steel wheels and 29s. Any chance it came with 4:56s maybe? Also, I don't plan on going bigger than 32", more likely back down to 31". Does the auto really need 5:29s for those?
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
