Sponsored by: CARiD
gear help..
Old Feb 23, 2009 | 08:28 PM
bkn's Avatar
bkn
gear help..
Hi, I got a 86 pick up 22r 31 tires and, I was wondering What gear ratio will best benefit me? I'ts my daily driver and I Run it at least 100 miles on the freeway, (daily). Any help is greatly appreciate it. Thank you
Old Feb 23, 2009 | 09:32 PM
904_runner's Avatar
I believe factory gearing for 31's would be 4.56's.
i am not sure with your motor. Maybe someone with a 22r can chime in
Old Feb 23, 2009 | 09:58 PM
toyNG's Avatar
4.56 if you have a manual transmission
4.88 if you have an automatic
Old Feb 24, 2009 | 04:39 PM
bkn's Avatar
bkn
Would 4.56 s be good for trailing. Thanks Everybody for the help.
Old Feb 24, 2009 | 04:49 PM
86tuning's Avatar
When you're offroad, in general, the lower the gears the better. So a 4.88 > 4.56.
When you're on the freeway, the closer the ratio is to stock, the more accurate your speedometer would be. That means 4.10 (on 29") is close to 4.56 (on 31") tires.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
