Sponsored by: CARiD
fuel filter
Old Sep 8, 2009 | 07:59 PM
moaky's Avatar
fuel filter
96' tacoma 2.4l straight 4 im looking for tips on replacing my fuel filter. for one im not sure i found it. i got a new one but what i think is it in the truck must be a casing for it. its right in front of the brake fluid res. also i know it holds pressure and i need to relieve it(dont know how to) a buddy said i could clamp the hoses on either side of it with C clamps. we thank you for your time. if you know of any good photos to show the way would be helpful. thank you for your time
Old Sep 8, 2009 | 08:27 PM
xwing777's Avatar
If its the same as my 91, your in for a world of hurt as its located directly under the intake on the passenger side. Look through the passenger fender and you will see it.
Old Sep 8, 2009 | 08:59 PM
myyota's Avatar
The fuel filter is under the intake manifold, NOT by the master cylinder. To relieve presure unscrew the gas cap, do not use C-clamps on the fuel lines unless you feel like spending alot of money for new ones. Look inside the passenger side wheel well, there should be an access panel that you can remove to get to the fuel filter, it will also make it alot easier if you remove the right front tire for better access
Old Sep 8, 2009 | 09:32 PM
Gokumono's Avatar
After replacing one 3 times within 1-2 weeks on the same truck... I got it down... Takes a lil bit of experience on how to twist ur arm/wrist around and where to put the ratchet. lol
I recommend taking off the neg terminal though... as I bout got shocked real bad the first time... left a nice lil black mark on the wrench.... idk what i hit.. but didn't wanna do it again.. took a couple sec to get hand off the wrench and out, as i was under the truck...
You may not have same prob, as it wouldn't surprise me if there was uncovered wire or something... but id be safe.
And if same as a 94 22re, should be able to do most from above...
Old Sep 11, 2009 | 08:09 PM
moaky's Avatar
well thank you guys for your help it was under the intake manifold but since mine is a 96 its totaly diffrent. its on the driver side looking through the wheel well between the intake manifold and the starter. you need a flash light cause its back in there. thank you for your help and tips
Old Sep 11, 2009 | 08:50 PM
toyota4x4907's Avatar
uh this is for a 2rz-fe guys, not a 22re.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
