Sponsored by: CARiD
front end creaks when turning sharp
Old Jul 22, 2006 | 11:55 PM
neilan's Avatar
ok this is prob a pretty simple question for someone to answer.
I have a 87 4runner stock suspention and wheels, except i have 31x9.5 tires.
When i turn to either alomost full turn or full turn goign in either forward or reverse i hear a loud very noticible creaking noise coming from the front end.
I have no clue what i could be?
Old Jul 23, 2006 | 12:01 AM
photoleif's Avatar
for starters, check out your ball joints. also, do you feel it in the steering wheel and is it a whine at all, or is it a pronounced, metallic creak? if it's more of a whine, check the steering. creak, check the ball joints and bushings. if possible get someone to sit in the truck and you listen. mine was creaking, and it turned out to be the ball joints -- well, the replacement for them, total chaos uniballs.
Old Jul 23, 2006 | 12:05 AM
neilan's Avatar
ya its definatly i metal creaking noise almost like opening a rusty door. And i was already thinkig nabout getting some ball joints and ball joint spacer because i have decided to do a ifs lift because of the stuff i drive on (mostly washed out logging roads for long distances and some mud but nothing where crazy travel is needed) but decnt travel helps at speeds. How much did you pay for your ball joints?
Old Jul 23, 2006 | 12:11 AM
ChickenLover's Avatar
This is a common problem. Smear some grease on your steering stops and the noise will stop. Do a search for further info.
Old Jul 23, 2006 | 12:14 AM
neilan's Avatar
ok thanks
Old Jul 23, 2006 | 04:33 AM
ovrrdrive's Avatar
Vote #2 for lube the steering stops...
Old Jul 23, 2006 | 08:20 AM
95RunnerSR5's Avatar
i have the same problem and thought it was my CV creaking since it needs to be replaced...
Old Jul 23, 2006 | 08:38 AM
rhettdog's Avatar
#3 for steering stops my '88 was famous for the headturning creak
Old Jul 23, 2006 | 09:10 AM
whitetaco02's Avatar
yeah, mine does the same thing when I am turning into the driveway. heck, my dad's 94 does that as well!!
Old Jul 23, 2006 | 09:43 AM
brandontrek's Avatar
yep mine does the same thing...when that happens everbody in a 20 foot radius gives me a look like "you sure that this is safe for the road..." i am gonna pick up some grease and lube them up...
Old Jul 23, 2006 | 11:18 AM
Tdubbs05's Avatar
ah i love getting solutions for things i thought weren't fixable!
Old Jul 23, 2006 | 01:26 PM
neilan's Avatar
yep thats what its was smeared some on ther and now its good.
Old Jul 23, 2006 | 03:19 PM
4x4Lamm's Avatar
What about a creak/metallic pops in quick sucsession when decelerating (not always in a turn). It has me stumped.
Lamm
Old Jul 24, 2006 | 05:57 PM
jakek's Avatar
New here. I also have the creaks, I guess I'll try grease on the steering stops. I just got my first 4Runner, it's an 86 and I've got the consecutive pops when stopping as well. Allready greased the BJ's and made sure they were tight. Mechanic said it might be the axle.
Old Jul 24, 2006 | 10:22 PM
thook's Avatar
And new plastic caps....maybe.
Old Mar 5, 2009 | 12:46 AM
dj_mr's Avatar
Unhappy 96 Toyota T100 noise
Ok I have a similar problem but mine only makes the clunking noise when I am in 4wd and turning a corner. I live in Massachusetts and require my 4wd often. Every storm we have had I need 4wd and hate turning a corner. It happens even with slight turns or hard turns. Clunks and shakes the steering wheel in your hands. Stock tires and they are not rubbing. HELP
lledwod
Aug 30, 2016 01:03 PM
Daneums
Aug 20, 2015 05:36 AM
smiley52
Jul 11, 2015 05:16 AM
toyoda8488
Jul 5, 2015 10:18 PM
