Sponsored by: CARiD
front axle for rear steer?
Old Feb 9, 2011 | 05:36 PM
atvsorus's Avatar
wanting to put front axel in rear upside down pointing foward to have rear steering will this work any comments thanks
Old Feb 9, 2011 | 05:43 PM
scuba's Avatar
Sure it will work. How you going to get a drive shaft to point towards it though? You'll have a crazy offset and the ujoints won't like you.
Old Feb 9, 2011 | 05:51 PM
atvsorus's Avatar
have dana 18 f&r passanger outputs ---ring & pinon still oil ok
Old Feb 9, 2011 | 05:55 PM
rattlewagon's Avatar
How are you going to steer the rear? Id make sure to up grade the shafts and trunion (sp) bearings. The rear end takes a lot of weight when climbing hills and rocks.
Interested tho..ill be watching.
Old Feb 9, 2011 | 06:00 PM
GreenFlames's Avatar
run the internal gears in reverse, they did this on Extreme 4x4 a while back. it was a pretty sweet rig. powered by an acura engine if i remember correctly.
Old Feb 9, 2011 | 06:03 PM
dropzone's Avatar
Fossilized
stock Birfs will not hold up...longfields or dirty 30's
there was a thread about this on pirate recently.
Old Feb 9, 2011 | 06:20 PM
atvsorus's Avatar
figure hydrolic steering like monster truck dont no about street legel
Old Feb 9, 2011 | 06:31 PM
http://www.spike.com/full-episode/bu...ggy-part/33169 <-----this will answer everything
Old Feb 9, 2011 | 06:38 PM
the engine in that link runs backwards, and they already flipped the axle to get it to the right hand side. so when he reverses the gears he is making the axle run as it would if it were not upside down. so remember that if you do go with the 4wheel steer set up.
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
