Sponsored by: CARiD
egr valve broken?
Old May 31, 2010 | 03:42 PM
shafner30's Avatar
egr valve broken?
hello
my egr valve opens and closes when i suck on the vacuum hose, but the engine does not
stubble or try to die....the idle does not change. what is going on?
let me know
i am getting a code 71
Old May 31, 2010 | 04:14 PM
TrikeKid's Avatar
A passage is blocked with carbon, had the same issue on an F150 I worked on.
Old May 31, 2010 | 04:37 PM
Countryhick's Avatar
Yea and how do you fix that i think hes gettin at??
Old May 31, 2010 | 06:35 PM
sb5walker's Avatar
I've heard of people using a lot of different things, carb cleaner, gasket remover, oven cleaner, toluene (can get from a professional paint store). Remove the tubes before cleaning & use new gaskets to reattach. Just be careful you don't blow yourself up or burn your skin off. In other words, don't mix chemicals & follow safety cautions for whatever you're using. Wearing those blue nitrile gloves is a good idea - you can get a box from any auto parts or hardware store. Gasket remover melts 'em, btw
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
Snort
Jul 9, 2015 03:58 PM
