did i burn my clutch?
ok the starter was already shot so push start i got stuck in a ditch\snow so im trying to get out and not kill it as im reving it [4x4] the clutch stuck to the floor and died i turned the wheel and poped up i towed it out and pushed start it in 2nd put in neutral and took tow strap off went to put in 1st would not shift turned off clutch shifted fine tried to push start and nothing i had it going like 10/15mph and nothing but shifted ok what did i do? clutch or starter?
Using some punctuation would make your post waaaay easier to read...a couple periods or comma's here and there. The transmission will shift fine with a bad clutch if the engine is off. The starter has no effect on how the transmission will shift. I'd say bad clutch..
sonorn67
Sep 19, 2015 05:39 PM
