Cylinder head diagnostic help
I am looking for some expert advice on an issue I have with a 22r motor. I've been told that this site is a great resource and it sure looks like it after searching through some of the posts here... Anyways, I just bought an old 89 toyota pickup to fix up. When I bought it, it was running like crap. Very rich and somewhat rough. I assumed a carburation issue. This truck has apparently been sitting in storage a very long time, only 90k miles on it. (I got the truck cheap enough I don't care even if it needs a new motor, but what I have found has me a little stumped.) When I bought the truck I checked the oil and noted no milk shake in the oil, just very dirty and a little gassy smelling (still thinking it is just running very rich). I begin to drive it home after I bought it and it begins to overheat on the freeway (I only drove side streets before I bought it, and it did not overheat.) So I shut her down before it hits the red line and figured maybe with all of the sitting, it is a stuck thermostat. I open the hood and my coolant reservoir is boiling... Dang. Maybe the temp gauge is off, since I shut it down before red line I didn't expect it to be boiling hot... So, I tow it home.
A few days later I fire it up and it runs the same, still no milk shake. I decide to flush coolant and replace thermostat. I remove the old thermostat (which was stuck closed by the way) and put it back together with no thermostat so I would get better coolant flow during the flush. So I have drained out the old coolant and put in water, I am still suspecting a possible blown head due to my hot episode, and who knows what the prior owner did... I observe the coolant through the open radiator and there are some very small bubbles and about every 30 seconds a little eruption of fluid from the radiator filler neck. Is this the water pump or combustion gas? The fluid also surges out when I accelerate the motor. So I've heard of this thing called a block test kit, I rent it from oreilly and try it out... It actually gives a negative test (meaning no combustion gas in the fluid) but I really don't trust this thing, one I've never used it and two, it started to melt from the steam coming out of the filler neck... So, I take the block tester back and get a compression checker. I plug that bad boy on and I get about 95s across the board! I figure this gauge is wrong as I have read this 22r won't run below 114s. I don't bother doing a wet compression check at this point. As a side note the plugs are blackened and slightly sooty, but only slightly moist on the #4 plug, which still makes me think the fuel air mixture is too rich, but that is a different problem....
I still strongly suspect a blown head gasket due to the history, but I have honestly never seen a blown head that didn't make milkshake. I don't mind pulling the head (I've never done it on this motor, but it looks relatively easy and would be a good learning experience.) but I don't just want to tear into it for grins... I am going to pull this carb and rebuild it anyways while I figure out if I should pull the head. Any and all opinions are appreciated.
Coolant system pressure tester done with the engine cold.
If your gasket has failed and pushing coolant into a cylinder it will show up.
The Milkshake is caused by a mix of oil and coolant or in the autos tranny fluid and coolant in the radiator.
Also these engines have a habit of air pockets in the coolant if it is not bled out.
If you got it cheap enough rebuild the engine and carb you will be good to go.
kgcwb44
Jan 29, 2023 10:02 AM
Blamalam
Mar 12, 2022 07:34 AM
Iceman4193
Aug 28, 2015 08:43 PM
