CV joint work: recently replaced boots can be reused, right?
Old 11-19-2007, 04:22 PM
retiring2texas's Avatar
Well, I am getting annoyed with that CV joint spindle bushing sound.
So, I am going to feel around for a good place to get the left CV joint worked.
I just had new boots put on outer/inner on both sides.
They can be saved and reused? I assume yes but want to be sure.
Yes or no?
Thanks guys.
Old 11-19-2007, 04:26 PM
eric-the-red's Avatar
If you mean the spindle bushings in the hub then the boots won't have to be touched. The entire shaft is removed and replaced in one piece.
Old 11-19-2007, 07:59 PM
tc
tc's Avatar
yep - basically, the hole where the CV goes through the spindle is where it needs to be greased.
NOTE: you can easily do this job yourself.
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
Kalihi,HI
07-09-2015 04:29 PM
Avenged
07-09-2015 07:55 AM
cyclist231
07-07-2015 12:56 PM
Quick Reply: CV joint work: recently replaced boots can be reused, right?
