coil or ignitor??
Hello there, I have a 1993 toyo 4x4 with the 2.4 4 cyl engine. My problem is when going down the road, and this has started to happen alot more is, my Tach needle starts to wander about, truck starts to miss, and my temp. gage starts to move back and forth. I know it is a short somewhere
The tach, which is stock runs off the coil, I think. and the coil and ignitor are next to each other so, should i just replace both, just not sure what else to do, as they seem to go together. Thanks for any help in this..............
Definitely start dong some testing before you just start replacing parts. yeah, start with your grounds, I had similar problems on my truck a couple years ago, it was the grounds. you just start repacing parts and you'll spent some bucks and still have the problem.
