Sponsored by: CARiD
Clutch start cancel button??
Old Dec 24, 2011 | 06:32 PM
mldave's Avatar
Step by step on how to use,please.Do I push button first,then turn key to on or vice versa,or do I push button and turn key to start while out of gear with the E-brake on?
Old Dec 24, 2011 | 06:52 PM
TylerH's Avatar
E-brake, put in neutral, turn key on, press button, start.
Old Dec 24, 2011 | 08:23 PM
Leviticus6432's Avatar
What a question...
Old Dec 24, 2011 | 08:53 PM
eric924run's Avatar
or you can leave in gear and drive around with your starter. kinda like a hybrid
Old Dec 24, 2011 | 09:02 PM
lmao your truck would love you lol
Old Dec 24, 2011 | 09:07 PM
Tofer's Avatar
Sponsor
it works great tho... first gear 4lo stuck on a hill. foot on the break and gas, push the clutch cancel button turn the truck over and give it a little gas.
Old Dec 24, 2011 | 10:10 PM
warmonger88's Avatar
Tofer,That was the only case I used mine also. I guess it would work ok if you want to start and run the truck without climbing inside, Just don't forget to take it out of gear.
Old Dec 24, 2011 | 10:22 PM
4wd4fun's Avatar
turn the key on and put the trans in neutral
put the trans in neutral then turn the key
then push the clutch start cancel button
then turn the key to start the engine
Old Dec 24, 2011 | 11:40 PM
DeathCougar's Avatar
Its a self destruct button.
DO NOT PUSH THIS BUTTON.
Old Dec 25, 2011 | 05:10 AM
bob200587's Avatar
I use it for both of those scenarios, or if I'm just too lazy to push the clutch in to start it.
Old Dec 25, 2011 | 07:16 AM
I'd use it all the time but it lights up when its on... and little things like that bother me lmao
Old Dec 25, 2011 | 09:00 AM
thook's Avatar
I've wired mine to eject unruly rear passengers. "Idiot Cancel" button. It's funny when their heads hit the rollbar on the way out.....
Old Dec 25, 2011 | 03:46 PM
takeitoutgetitdirty's Avatar
I have to remember that one.
I have used the button when my master cylinder went out on me. I put in gear at a stop sign and start it, once I got to a certain RPM it would shift up fine. (Not good for tranny, but got me home) When coming to a stop, I would pull it out of gear and shut it off and start all over again. Luckily it went out when I was on backroads with no traffic.
mskalmus
May 28, 2017 07:51 AM
msane99
Jul 11, 2015 08:08 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
raiderhawks00
Jul 8, 2015 06:23 PM
karbin
Jul 5, 2015 11:37 PM
