Sponsored by: CARiD
clutch not working, Just installed engine
Old Dec 11, 2007 | 08:31 PM
Bullelk's Avatar
Hi all, just install a engine in a 90 toyota 3vze, motor works awesome but the clutch is not ingaging, slave clylinder looks to be extended, clutch is really soft,
Old Dec 11, 2007 | 08:56 PM
rowdy235's Avatar
so by not engaged, you mean there is no drive, even with the clutch pedal out? Probably air in the lines. Bleed system per instructions in a service manual.
Old Dec 11, 2007 | 09:02 PM
DeathCougar's Avatar
or you installed the clutch disc backwards! Oops!
Did you disconnect any of the hydraulics of the clutch when removing or installing the engine? If not, you may have lost a master cylinder, or installed the disc backwards.
Old Apr 19, 2008 | 04:36 PM
oldgold3vze's Avatar
I'm also struggling with this same issue, so any help would be much appreciated. The only difference is mine is a 22re, and the donor motor had the existing clutch already installed, so I just decided to use it.
voiddweller
19
May 2, 2016 09:10 PM
gog1968
Jun 22, 2015 05:55 AM
Mohamed
17
Aug 21, 2002 12:54 PM
