Changing rear axle
I have a 2003 tacoma, non trd. I really want the manual locking rear differential on my truck. Would it be farely easy to buy a trd rear locking differential from a junk yard an put it on my tacoma. I was thinking about buying the whole rear axle and replacing it with my rear axle? Is this crazy?
https://www.yotatech.com/forums/f2/e...rd-gen-151537/
try this one i didnt read through but it should help
You need the actuator for sure, but you can hook it up without the e-locker computer. In my opinion, it would be easier, and not a big difference in price, to put in an ARB air locker and compressor instead, then you end up with a better locker.
I will stand by the fact that an ARB locker would be more reliable than the Toyota e-locker in its stock form. The e-locker actuator is problematic and seems to require frequent periodic maintenance to keep it working properly... at least in the east coast Canadian environment, anyways.
Well, he never said anything about the manual actuator, I just kinda threw it in there. If I was doing an elocker axle swap on my truck, that's how I would do it, rather than getting all the elctronics and such...
I feel the e-lockers are better and more reliable. In a pinch, if the motor goes out you can unlock/lock it by hand. If your ARB gets a leak or anything, you are stuck with an open diff....
Plus I trust wiring more then air lines
Just my opinion but if I was going to the trouble to install an elocker then there is no way that I would use a piece of crap cable to lock and unlock it. Isn't the "e" the best part of an elocker?
I put two of them in my 85 4Runner and control them with an FZJ80 elocker ECU and switch. You might read this thread if you want to get an idea of what's involved:
http://forum.ih8mud.com/79-95-toyota...-switches.html
There are links in that thread to people that have done the rear only retrofit on Tacomas and newer 4Runners. Also lots of good info on alternatre control possibilities.
hah, Wow, If your anywhere around socal. https://www.yotatech.com/forums/f11/...r-axle-166689/ just came up tonight !!
I've seen that happen to a couple but something must have happened to the seal on the actuator or they managed to get the breather connection underwater. The brand new, out of the box factory units are completely sealed. At least mine were.
And if installed properly, you really shouldn't have an issue with the electric actuator. They are sealed pretty well.
jerusry
Oct 19, 2015 05:28 PM
icentropy
Jul 9, 2015 02:12 PM
toyoda8488
Jul 5, 2015 10:18 PM
