Sponsored by: CARiD
Can't get parking lights to turn on
Old Nov 27, 2009 | 01:51 PM
peow130's Avatar
Title says it all, my parking lights won't turn on.
I spliced in the ground for my blinker for a blinker mod, and i cant get the parking light to turn on with the lights, regardless of whether the blinker is on or not. I also tried with the hot side of the blinker, and it made the light blink but i cant get the parking light to turn on..
Is there a fuse for it somewhere, because i cant find the thing at all..
Old Nov 27, 2009 | 10:00 PM
peow130's Avatar
>.>, so no ideas anybody?
Old Nov 27, 2009 | 10:55 PM
Green_slime's Avatar
take your steering cover off the steering colum and take the light switch apart at the steerin wheel their are copper contacts in their and they get gummed up i had the same problem with mine and now they work fine
Old Nov 27, 2009 | 11:17 PM
olharleyman's Avatar
Did you put all your grounds together when you did the blinker mod?
I just did the mod myself and put all the grounds from the blinker,parking light and the new GM socket together and it all works perfect if you forgot to add your parking light ground in line you will end up with no parking lights just a thought
Old Nov 28, 2009 | 11:57 AM
peow130's Avatar
olharley, i'm using the original style light, just setting it so that the blinker ground will go into the hot side of the light and turn it off when the blinker is on. it's the easiest way to do it, lol.
Old Nov 28, 2009 | 08:22 PM
peow130's Avatar
okay, well i've got my blinkers working....
HOWEVER i cant get my parking lights to work AT ALL..
blinkers work fine through the GM style blinker/corner light combo..
i even tried just hooking up the old style lights onto the wiring, no dice either.
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
Odin
Jul 15, 2015 09:28 PM
