Sponsored by: CARiD
bang for the buck - engine mods
Old Feb 20, 2011 | 04:09 PM
solowookie's Avatar
I registered yesterday, and the day before that, yesterday, and today I have been searching the forums looking at various engine mods. so far it appears the most popular mods are, in on particular order, VAFM, headers, and IRS mod (some doing the swiss cheese mod to their airbox as well).
I need 'bang for the buck' upgrades. things that are extremely cheap, but that have results.
so far I see IRS as the best 'bang for the buck' mod followed by VAFM if you can get the parts cheaply enough, and have the expertise to truly tune if needed (that means it is proably out for me). am I missing anything?
headers will come down the line if for no other reason than to decrease the chance of blowing a head gasket to me the other benefits are good, but second to this benefit.
Old Feb 20, 2011 | 05:51 PM
Airo Spade's Avatar
what engine do you have
Old Feb 20, 2011 | 05:52 PM
Airo Spade's Avatar
and look up the toyota bible 2.0 and use google it will tell you tons of mods
Old Feb 20, 2011 | 07:05 PM
solowookie's Avatar
the 3.slow...
Old Feb 20, 2011 | 08:04 PM
toyota4x4907's Avatar
ISR. Its not the Internal Revenue Service
What VAFM mod are you refering to?
Honestly, I think ISR, then replace the exhaust with larger pipe and new cat.
Old Feb 20, 2011 | 08:18 PM
solowookie's Avatar
well - if I put the IRS under my hood it would even be more useless I presume. what is the stop size of the exhaust?
I've seen a few VAFM mods - one out of a celica, supra (not the one for the 22RE) I have the links stored off. any of them that swap straight in, but depending on the post they all seemed like that may require some tuning.
Old Feb 20, 2011 | 08:29 PM
bigarms23's Avatar
for a 3.0 a fipk k&n kit with a free flow exhaust and a set of headers
Old Feb 20, 2011 | 08:38 PM
Stock size is like 1 7/8" ID I believe. Maybe 2". 2.25" seems to be most peoples favorites. Works great for me with my 22re.
Old Feb 20, 2011 | 08:48 PM
solowookie's Avatar
exhaust & headers are out of the question for now. I would really prefer a set of shorty ceramic coated, but I really don't see any good options for one. I prefer the torque out of a good set of shorty headers. I will do them, but not yet (out of the budget)
priority - doing a few mods for a total cost of under $100 for all mods. (middle aged guy going back to college on a budget, this is my daily driver) next priority - getting my transmission rebuilt so it goes into reverse all the time (5 spd). after that I can worry about exhaust / headers. (I can get by with the transmission they way it is until I can graduate college in early November, and get a job). I could probably get a used one cheaper, but depending on the deal I would almost prefer the peace of mind with a new rebuild (have a very good shop I trust).
another mod I was considering with the ISR for now was a coil. I've had good luck with coil upgrade / power on my old GM vehicles. looking at the stock coil on the Toyota I'm thinking this is an easy / cheap please to upgrade that may give me more power.
$30 GM Coil Upgrade
7mge coil
Old Feb 20, 2011 | 08:58 PM
All the older Yotas I have owned and others I have driven had trouble going into reverse sometimes. Try going into second gear then into reverse. Its a habit for me now...
Also could be as simple as the shifter seat bushing.
Old Feb 20, 2011 | 09:06 PM
solowookie's Avatar
I'll have to do some searches on that seat bushing, and see if I can't find something. thanks for the tip on going into 2nd. I've been able to get it in by trying other gears, but hadn't really made a correlation yet between getting it into revere, and what specific gear to try first.
I presume the bushing you are referring to is right on top basically between the gear shift & the transmission per say?
Old Feb 20, 2011 | 09:19 PM
Ya, it goes on the bottom of the shift lever, AFAIK. I couldnt find it in the FSM for either the G58 (what I have) or the R150F (what you have). I know when the bushing wears out they can make the shifter sloppy and sometimes not stay in gear. Pretty sure it can possible interfere with shifting too....
Invaluable resource:
http://www.ncttora.com/fsm/1990-1995...es/repair.html
Old Feb 20, 2011 | 09:31 PM
solowookie's Avatar
I'm wondering if that is the problem then it has slipped out of 5th gear on me a few times when I was going up hills, and it was under load before I down shifted to 4th. I'll check it out thanks for the tip.
Old Apr 18, 2012 | 06:07 PM
pac6's Avatar
what is the isr mod? im running a 93 4 banger 22re 5 speed manual cold air no cat 31 inch tires . 245.456 mile and looks like a lort more to go
Whatever123
Sep 30, 2015 12:12 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
mickyd9990
Jul 6, 2015 09:01 AM
wilbertd
Jul 6, 2015 07:39 AM
