Sponsored by: CARiD
ball joint spacer height vs actual lift
Old Nov 4, 2013 | 04:57 AM
Andy A's Avatar
Looking around I see that ball joint spacers can come in various height. I would like to add approx 1\2 to 3\4in to the front. So does a 1\2 in spacer give 1\2in in lift or is it an approx and vice versa for a 3\4in.
At what point in additional lift on a stock front end does one start running into extreme halfshaft angle issues.
Old Nov 4, 2013 | 05:01 AM
HighLux's Avatar
Most do a diff drop kit @ 2" spacer
Old Nov 4, 2013 | 07:20 AM
93Xtra-Cab's Avatar
If it's a 1/2" ball joint spacer, you'll get 1/2" of lift.
Now, the largest ball joint spacer I've seen is 1.5". If the company is selling say a 2.5" ball joint spacer lift, it is a 1.5" ball joint spacer and you have to crank the torsion bars to get the other 1". 1.5" is basically the tallest spacer before you run into CV troubles.
If you're only planning on a 1/2" or 3/4" spacer, don't even bother with a diff drop. I don't even know a place other than 4Crawler that sells less than a 1.5" spacer.
Old Nov 4, 2013 | 10:30 PM
Andy A's Avatar
4crawler will do custom 1/2 or 3/4 in, just have to special order them.. One of the purposes for the customs according to their website was they mainly make the custom sizes to piggyback on the 1.5's so one could get more than 1.5in without cranking the T bars.
Was looking for just a little bit of lift on the front because the rear has some additional leafs and wanted to get it a little more level.
krimsonone
Sep 13, 2024 09:33 AM
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
