Ball Joint lift vs Body lift vs SAS
Old 09-08-2011, 07:56 PM
dsal_86Yota's Avatar
Lightbulb Ball Joint lift vs Body lift vs SAS
So not sure what to do. Got my 86 yota and not sure what to do for lift too. Considering a ball joint lift. Will get 1.5-2" from it. It cost bout $200 with add-a-leafs for rear. Then thought bout doing 2" body lift but no sure if worth it. Then would love a SAS but coat and the pain of finding a front axle that s not outrageous cost. The SAS would be a dream but finances are not there and don't have garage to work in. So leaning towards Ball Joint lift. Anyone done it? SAS may come later
Old 09-08-2011, 07:57 PM
Not Coat Ment COST
Old 09-08-2011, 09:30 PM
vasinvictor's Avatar
You want additional lift or replace your torsion bar crank? You need to clear those 35s? Why do you not like your current setup? More info needed about what you are trying to achieve.
Old 09-09-2011, 04:46 AM
waskillywabbit's Avatar
Body lift $150-200
BJ & AAL You will want longer shocks $400
SAS $4500
I'd pick the middle one.
:wabbit2:
Old 09-09-2011, 07:01 AM
I did the torsion crank 6 years ago. Its starting to sag back down. The 35s are pretty worn out. Got them free from a buddy when I did torsion lift. So new tires are in order. Its got 31s on it now cause they have more meat, plus im letting my little sister use it. Thinking of going 33s.
Old 09-09-2011, 07:02 AM
More solid of a lift is what I want.
Old 09-09-2011, 07:07 AM
Plus need new shocks anyways. Busted front mounts and overloaded rear with rocks when I was doing my driveway
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Cabell
07-24-2015 12:14 PM
ksmudrunner99
07-21-2015 05:33 AM
Quick Reply: Ball Joint lift vs Body lift vs SAS
