Sponsored by: CARiD
Air cleaner housing quandry
Old Jul 22, 2010 | 10:31 AM
krytellan's Avatar
Hey all. This here is the air cleaner assembly. The black box I know is part of the original air cleaner assembly and I presume it's important as it appears (?) to send air into the manifold. The problem is whoever put this K&N in did a horrific job and the box has been sitting on the alternator wheel putting a huge gash in it. I am guessing that's bad as it will allow dirty air in the system.
My question is what are my options? I cannot identify this part to save my life and have only seen it in conjunction with a complete OEM air cleaner housing. Any suggestions?
Old Jul 22, 2010 | 11:51 AM
myyota's Avatar
Just remove it and put a small cone filter in its place.
Old Jul 22, 2010 | 11:55 AM
krytellan's Avatar
You mean a small inline filter cartridge-type thingy?
Old Jul 22, 2010 | 02:04 PM
myyota's Avatar
Just remove the hose and air box and put a small cone filter in its place, all that box is - is just a resonator and if i remember right its part of the emissions junk. The original owner should have just removed it and put a small filter in its place, but he left it for you to do. Most auto parts stores carry small filters, look in the ricer section.
Old Jul 23, 2010 | 06:50 AM
thinsley's Avatar
I just (last night) installed the same K&N on my truck. The PO that installed it must not have doneit correctly because after installation, you should have good clearance. It sounds like you may be missing one of the brackets. I would also try contacting K&N, look at your parts, I'd try to get them to send you one of the brackets. You should have 3 brackets bolting all that stuff to your rig. 2 come off of the big black cricle thing, and one comes off the MAF. I hope I'm getting these terms right, but I'm sure you'll know what I mean. Just my .02
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Tacoma1313
Aug 17, 2015 05:44 PM
calderp
Jul 27, 2015 09:58 AM
CanRunner
Jul 20, 2015 01:29 PM
A2theK
Jul 12, 2015 10:46 AM
