Sponsored by: CARiD
96 4Runner - Shocks/Springs Help
Old Jul 27, 2006 | 10:21 AM
CU4runnerSR5's Avatar
Question 96 4Runner - Shocks/Springs Help
I have a 1996 4Runner SR5, 4WD, manual trans with 110k miles. I want to replace the rear coil springs as well as the front shocks and springs. I have already replaced the rear shocks with Ranchos. I do a little off-roading, mainly while camping or mountain biking, but it is primarily a street vehicle. I don't want a lift, I just want to improve the ride quality (maybe a little stiffer) and fix the sagging rear end. I have searched all over and cannot find anyone who sells simple replacement coil springs that are not for a lift kit. A front shock / coil spring assembly would be ideal. Can anyone recommend where to buy these? Also, is it necessary to replace the front strut mounts?
Thanks
Old Jul 27, 2006 | 05:41 PM
Gerdo's Avatar
I wanted stronger/new coils also. I did the TRD/OME lift. It is a MILD lift. Check out my 4Runner.
Old Jul 27, 2006 | 06:19 PM
neliconcept's Avatar
if you want to just about an inch higher but also improve quality
the pp lift springs and bilsteins is a good set to look after
www.performanceproducts.com have both and will def fix the rear sagging issue.
Old Jul 28, 2006 | 06:38 AM
Thanks for the advice. I have also read that people replace the rear coils with 99 stock coils springs. Does anyone know where I can get those? Is that something that you can only get through the dealer?
Old Jul 28, 2006 | 08:21 AM
A couple more questions...neliconcept, you suggested the pp springs with bilstein shocks. What I'm confused about is how to assemble the front shock/spring. Do the bilsteins for the front have spring seats built in? The pics on the performance products website do not seem to show spring seats on them, but it could just be a generic pic. Do they come with the necessary hardware to mount the springs to them? Do I need to buy new strut mounts or can I reused the old ones?
Thanks for your help.
Old Aug 2, 2006 | 10:03 PM
AxleIke's Avatar
Hey dude...You in boulder? If so, i'd love to meet you sometime...
The front is a strut on those and i recomend getting it installed at a shop. You can rent a spring compressor from autozone, but i had one bust on me, and almost broke my hand. Plus, if they are assembled at a shop, its less down time on the truck.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
