94 Toyota pickup 2wd front hub remove help
I have a 94 pickup 2wd and i want to know how to remove the hub from the rotor. The hub has five bolts that hold the rotor with, is that the only bolts i need to remove thanks in advance.
No. Once you remove the cotter pin and big nut in the center, the whole hub and rotor will just slide off. When its about half way off the spindle, push it back on and the outer bearing will be sitting on the threads where the big nut goes.
6th Gear
19
Dec 10, 2019 07:31 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
