Sponsored by: CARiD
94 toyota 22re
Old Jan 24, 2013 | 05:16 PM
redneck17's Avatar
94 toyota 22re
I came home last night and raised the hood to see if I could see any sparks because I have a surge, just making sure it was not a bad wire or cap. Then I noticed that the exhaust manifold was red hot. Any reason why this would be.The shop said the timing was right.
Old Jan 24, 2013 | 05:21 PM
Discombobulated's Avatar
Clogged cat???
Old Jan 24, 2013 | 05:33 PM
redneck17's Avatar
No cat been removed
Old Jan 24, 2013 | 06:10 PM
combatcarl's Avatar
Vacuum leak. Makes it run lean, detonate, turn the manifold red if its bad enough at speed/loads. Check your vacuum.
Old Jan 24, 2013 | 06:16 PM
niall's Avatar
Running lean in general. Likely a vacuum leak as said above, so start there, could also be a clogged injector, bad filter, pump going bad.
Old Jan 24, 2013 | 11:20 PM
combatcarl's Avatar
True. Any lean condition will cherry up your headers if its bad enough. But the hunting idle made me think vacuum.
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
