Sponsored by: CARiD
94 hilux miss
Old Apr 7, 2017 | 09:14 PM
Owen Hampton's Avatar
Thumbs down 94 hilux miss
my 94 22r helux has a miss and I cant figure it out.... I have done timing carb plugs leeds valves compression test and replaced leeking manifold gasket...
please help me
Old Apr 19, 2017 | 07:37 PM
az4x4runner's Avatar
Missing at idle or under load?
Did you check the condition of your distributor cap/rotor? Test ignition coil?
http://www.teamtoyota4x4.org/archivi...e/onvehicl.pdf
Old May 1, 2017 | 04:40 PM
UTAHYOTA's Avatar
Take a look at all the grounds for your ignition as well. I had a similar problem and it was a corroded ground. I fixed the ground a couple of months ago, the gripe hasn't reappeared.
