Sponsored by: CARiD
93 Toyota pick up BIG PROBLEM truck wont move
Old Dec 2, 2011 | 04:47 PM
Tawny Jensen's Avatar
Question 93 Toyota pick up BIG PROBLEM truck wont move
I have a 1993 toyota pick up. Recently I was driving up a hill and out of no where the truck lost all power and I began to roll backward. Once I rolled into a safe spot I the truck started back up but would not go anywhere. I have tried all the gears I had it towed home and the tow truck driver said all 4 wheels were locked up he eventually got them to unlock by pushing the truck back and fourth. But I still have the same problem the truck will start but goes nowhere. I was thinking the cluch or transmission might be the problem but I'm not sure.
ANY IDEAS???
Old Dec 2, 2011 | 04:51 PM
James Woods's Avatar
Check the transfercase and transmission fluid for metal or anything, I assume we are talking about a 5 speed since you said a clutch.
Old Dec 2, 2011 | 05:22 PM
I checked the fluid and there are no metal shaving or nothing like that and I don't know if it matters or not but there was no noies or grinding issues before the incident
Old Dec 2, 2011 | 05:23 PM
yoder519's Avatar
so the truck wont move, or it will roll? i had this happen and the pinion in teh rear end stripped out., the truck woudl roll, but woudlnt hold its self or move under throttle. doubt this is your problem though if the 4wheel drive wont move it
Old Dec 2, 2011 | 08:46 PM
The four wheel drive does the same thing I can get the truck to go into each gear but the car won't move any thoughts
Old Dec 2, 2011 | 09:04 PM
justin_4runner's Avatar
when u are trying to get it to move does the truck bog down or idle not change? could be brake issue. for all 4 tires to lock up unless u where in 4wd thats the only thing i can think of that would cause all them to lock up.
Old Dec 2, 2011 | 09:30 PM
94 toyota 12" lift's Avatar
ok transfer case is controlled by the transmission so if the truck will roll but does nothing at all movement wise in gear i would recomend to drop the transmission and transfer take it to a transmission shop and have them check it out thats my bet to your problem i saw this happen before i forgot what the problem ended up being.
Old Dec 3, 2011 | 05:15 AM
xxxtreme22r's Avatar
Really? We don't even know if this truck for sure is an auto or manual trans yet. He did say clutch though. And if that's the case, the transfer case is NOT controlled by the transmission. How the heck are people giving recommendations when we don't even know what type of trans this is. As well as if this thing is a v6 or 4cyl.
Old Dec 3, 2011 | 05:20 AM
waskillywabbit's Avatar
Automatic or 5 spd?
You mentioned a clutch.
:wabbit2:
Old Dec 3, 2011 | 05:25 AM
Dang wabbit you beat my edit. lol. Also if it is an auto then we need to know if it's a v6 or not and if it has ADD or factory manual hubs. Because the only transfercase in that truck that is controlled by the transmission is in the v6 Pickup not the 4cyl. And that v6 truck has to have ADD and not manual hubs. ie A340H and not an A340F.
Old Dec 3, 2011 | 03:59 PM
Its a manual v6
Old Dec 3, 2011 | 04:03 PM
Then your transmission doesn't control your transfer case, ignore that above related comment.
Old Dec 3, 2011 | 04:28 PM
Teuf's Avatar
Subcribed..........
Old Dec 3, 2011 | 04:29 PM
Teuf's Avatar
OOOOOOps forgot an s,,,,,,,,, Subscribed
Old Dec 4, 2011 | 08:20 PM
I want ti verify with everyone, what is your suggestion? I had a lot of mixed opinions and just want to make sure I'm having the right part looked at.
Old Dec 4, 2011 | 08:34 PM
RRogers's Avatar
Does the engine bog down when you let off the clutch? If it does, try putting the transfer case in neutral and then try it. If it still bogs its likely not the tranfercase. Try putting the tranny in neutral, if it still bogs then I would say it is the clutch, if it doesnt then its probably the tranny. If it does normaly bog when you left off the clutch and it doesnt when you have the t/c in neutral then I would say it is somewhere in your driveline or axle/wheel area. may save you a little $$$ by narrowing it down.
Old Dec 5, 2011 | 12:19 PM
The engine never bogs down and I dont know if its important but I can push the shifter into each gear really easily without pushing in the clutch.
Old Dec 5, 2011 | 12:39 PM
RRogers's Avatar
If you can put the shifter in any gear while the engine is running without using the clutch, chances are your clutch is gone.
Old Feb 6, 2020 | 12:03 PM
Arkansas62's Avatar
Red face
Hello
Can you tell me why my 93 Toyota Pickup DLX will not come out of gear please. Thanks
Old Feb 6, 2020 | 12:06 PM
Arkansas62's Avatar
Hello
