Sponsored by: CARiD
90 3.slow, bad mileage, boggy, fuel smell when cold
Old Mar 20, 2011 | 04:44 PM
90blueyota's Avatar
I have read many threads about bad mileage or leaking fuel, but none with all my symtoms.
Truck starts ok when cold, seems boggy, have to feather the throttle to move the truck. It it stalls when trying to move it, very hard to restart (have to almost hold it on the floor to get it to refire)
Also smells of gas when cold (seems to be coming from the exhaust, not anything leaking under the hood)
Once its warmed up, seems to run pretty good, maybe a little more guttless than the normal guttless feeling it has always had......
terrible mileage (even by 3.slow standards as far as I have read) Mileage is like a quarter of a tank in 25-35 miles or so
seems to be getting way too much fuel, I am thinking it could be a coolant temp sensor, o2, or maybe a fuel pressure regulator leaking into the vaccuum line hooked to it.
Any other ideas or known problems?
Old May 17, 2011 | 11:44 AM
90blueyota's Avatar
Changed coolant sensor, air filter and new cat converter and exhaust.
Still boggy when cold, get bad mileage sometimes, other times its fine
suggestions?
Old May 17, 2011 | 11:48 AM
alil2cul4u's Avatar
I have the same problem as far as this goes.. I am not sure what could be causing it!
Old May 17, 2011 | 01:28 PM
90blueyota's Avatar
Already checked the fuel rails for leaks etc. Bad mileage sometimes as well, but not always
Old May 17, 2011 | 02:56 PM
Team420's Avatar
Check tps? When they start to go out, I always notice they do it spurts, until it just dont work... afm as well.
Old May 17, 2011 | 03:25 PM
90blueyota's Avatar
is there a procedure for checking either of those items? I am assuming ohms resistance open, vs closed or something of the sort
Old May 19, 2011 | 03:49 PM
90blueyota's Avatar
It seems to do it more when its cold outside.....
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
