Sponsored by: CARiD
87 Toyota making weurd noise
Old Sep 1, 2012 | 10:28 AM
Yodderz87's Avatar
Lightbulb 87 Toyota making weurd noise
My 87 Yota, 5 speed with 22r motor is making a weird noise from the tranny. Sounds like a weed eater. Thought it was my throw out bearing, but when I dropped the tranny the throw out bearing is still good. When the clutch is in the noise stops, but in gear its a loud rattling. What could it be?
Old Sep 1, 2012 | 10:44 AM
Philbert's Avatar
Could be bearings
Rotate flanges by hand with tranny out of truck. Do it in all gears and in 4x4 low and high. Listen....hear dragging noises? Then probably bad bearings.
If bad bearings then gears are not aligned anymore and will wear each other down until the whole thing grenades.
Old Sep 1, 2012 | 10:45 AM
rokblok's Avatar
What about in neutral with clutch out?
Old Sep 1, 2012 | 10:55 AM
Philbert's Avatar
I would imagine you would still hear something in neutral if bearings are bad, since the input shaft turns no matter what (and there is a bearing on that...mine failed).
Old Sep 21, 2012 | 02:12 PM
Yodderz87's Avatar
Thank you all for your comments, it is greatly appreciated. I beleive my issue is far more than what I thought. I have lost 1st-3rd gears in my tranny. So I am on the look out for another tranny that I can put in.
Dillon1983
Jul 7, 2015 06:47 PM
camdenbuck
Jul 7, 2015 07:33 AM
87blyota
Jul 1, 2015 05:26 PM
dlotoy4runner
7
Jul 9, 2002 01:11 PM
95Runner
Jun 9, 2002 08:56 AM
