Sponsored by: CARiD
85 front axle question?
Old Oct 27, 2009 | 10:13 PM
Romix's Avatar
I'm going to be purchasing a 85 front axle this coming weekend... Just wanted to know what I should look out for as far as problems and how worn out it is
Old Oct 27, 2009 | 10:19 PM
muddpigg's Avatar
if its bent.
Old Oct 28, 2009 | 09:26 PM
Romix's Avatar
I guess that would be obvious just by looking at the housing right?
I'll be putting 5.29's in it so a good servicing will be in order with that...
Any other pointers?
Old Oct 28, 2009 | 10:07 PM
EWAYota's Avatar
On some you can tell right away its bent. I've got one sitting outside that we didn't know what bent till we tried taking out the long side axle shaft. Took 20 minutes to get it popped out and then we could tell it had a smile to it.
Bent is about the only thing you can really worry about. You could be weary of the ring and pinion but most plan to regear and that fixes that. Other than that, you'll be needing to rebuild it anyways so leaking seals don't matter much.
Old Oct 28, 2009 | 10:49 PM
Romix's Avatar
would locking in the hubs and turning things be a good idea then?
Old Oct 29, 2009 | 06:38 AM
Romix's Avatar
bump for the day crew
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
