85 front axle question?
On some you can tell right away its bent. I've got one sitting outside that we didn't know what bent till we tried taking out the long side axle shaft. Took 20 minutes to get it popped out and then we could tell it had a smile to it.
Bent is about the only thing you can really worry about. You could be weary of the ring and pinion but most plan to regear and that fixes that. Other than that, you'll be needing to rebuild it anyways so leaking seals don't matter much.
Flying91
45
Apr 11, 2024 04:39 PM
jerusry
Oct 19, 2015 05:28 PM
