Sponsored by: CARiD
85 Diesel Wont Start!
Old Feb 3, 2010 | 08:06 PM
85turbodiesel's Avatar
Question 85 Diesel Wont Start!
Im new to this forum and figured this is the best place for some help. I have searched and searched and cannot find anything that helps. I have a 1985 2wd diesel pickup. I recently hurt my leg and could not drive my truck because its a stick so it has been sitting for about 1-2 months.(Now for the problem) The truck started right up with no problem, but then after 10 seconds it DIES! Now i cant get it started at all. I have checked my glow plugs, fuese, battery and belts. With an ohmmeter I am getting up to 7 volts at the glow plugs (is that right?) Also, is it possible for the diesel to go bad after 1 month? -thanks in advance for any help
Old Feb 13, 2010 | 12:24 PM
nj110167's Avatar
ok well the glow plugs arent even necessary except in winter wich it is.. but check your primer for your fuel line you might have a hole in your line prohibiting diesel fuel from reaching the necessary pressure to reach the injectors i dunno about toyota but cummins cat and detroit diesel injectors open at over 2000 psi it sounds to me like you need to do some priming it takes like a good 10-15 min of pumping sometimes
Old Feb 13, 2010 | 12:25 PM
nj110167's Avatar
also 7 volts wouldnt be enough to start the truck i think you need at least 10 try battery box or someting but i would check the fuel first
Doug4320
Mar 24, 2018 10:11 PM
nick b
Jul 11, 2015 04:38 AM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
