Sponsored by: CARiD
84 pickup gas tank removal help needed
Old Dec 5, 2010 | 07:58 PM
riptricket's Avatar
How do you remove the gas tank float that tells how much gas is in the tank? Also, how would one replace/fix it?
Old Dec 7, 2010 | 05:09 AM
541SR5's Avatar
If you're talking about the sending unit, its a pretty easy fix (assuming its like my '81). What might not be easy to actually getting to it. I was able to get to mine because the I took the bed off for restoration. Mine had one wire harness plug in and 6 little screws and out it came. I got a new one surprisingly enough at the dealership for $95. If the bed is not off, then maybe lower the tank and it ought to be pretty straight forward.
Old Dec 7, 2010 | 05:25 AM
dropzone's Avatar
Fossilized
Down load the fsm using the link in my sig
Also I will fix your title, Taco's didn't come out till mid 95
Yont283
Sep 23, 2022 08:06 PM
crazypaint
Jun 23, 2015 03:27 AM
HALMAN
Jun 14, 2002 09:02 PM
westbound
Jun 7, 2002 03:30 PM
