Sponsored by: CARiD
84 22r Toyota pickup 4x4 firing issues
Old May 10, 2019 | 02:58 PM
Yotalife89's Avatar
so I have a 84 Toyota 4x4 pickup the truck will not fire with the ignition switch but will bump start fine. I just built the motor and have replaced the battery the alternator and regulator along with distributor and have done a hei gm conversion and the ignition switch. It has to be bump started. I’m getting 12v to the coil. Just for the info I did the hei gm conversion due to thinking the original stock ignitor was bad. I have no idea where to go from here or what to try to get it to fire I have run a hot wire directly to the coil with absolutely no change any help would be amazing!
Old May 10, 2019 | 03:22 PM
Co_94_PU's Avatar
Have you verified spark from the ignition while the key is in the start position with your timing light?
Old May 10, 2019 | 03:36 PM
Yotalife89's Avatar
I have not tried a timing light but I have grounded a spark plug against the block to see no fire at all I can try the timing light tho
Old May 10, 2019 | 03:44 PM
Yotalife89's Avatar
Just checked with timing light and nothing I’m assuming you ment while cranking the truck.
mulewright
Oct 3, 2015 02:47 PM
Belize Off Road Team
3.4 Swaps
50
Feb 11, 2013 05:24 PM
tlucyk
Mar 29, 2011 07:21 AM
80yotaman
Apr 19, 2009 08:34 PM
LKQSJH
Sep 3, 2006 08:30 PM
