Sponsored by: CARiD
3" body lift questions?
Old Feb 19, 2009 | 02:12 PM
dayota's Avatar
I have an 89 extended cab pickup. I would like to do a 3" body lift. The kit I was looking at comes with bumper brackets and steering extension and all the blocks of course. I want to do the 3" and not the 2" so what problems will i run into. Gas tank hose is not a prob and neither is wiring realy. I can extend the shift levers no problem. Is there anything else major to think about? Any suggestions?
Old Feb 19, 2009 | 02:21 PM
toyNG's Avatar
Almost any question you have regarding body lifts can be answered by information found here http://http://www.4crawler.com/4x4/F...yLiftKit.shtml
Old Feb 19, 2009 | 02:33 PM
dayota's Avatar
K thanks
Old Feb 19, 2009 | 03:42 PM
waskillywabbit's Avatar
Glad you found Yotatech and hope you learn all about Toyotas. Please learn to search a bit more and post your questions in the appropriate forums.
Moved to Newbie forum.
Old Feb 19, 2009 | 03:49 PM
dayota's Avatar
not to be rude but it said this is where to put body lift questions but thanks i guess
Old Feb 19, 2009 | 04:01 PM
Yes, you are correct.
However, if you had searched the forum for "body lifts" or used a for "Toyota body lifts" you would have surely found the answer you were needing quickly, which is the link posted above to 4crawler.com.
A little more effort on your part to find your answers will be beneficial in the long run because if you keep asking basic questions oustide of obvious searching, and not in the "newbie" forum, folks will stop answering your questions and then when you have a genuine one you won't get the help you need. Make sense?
Just trying to save you some frustration.
Good luck with your body lift.
Old Feb 19, 2009 | 04:53 PM
dayota's Avatar
ya ic. thanks
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
