Sponsored by: CARiD
2wd Rear locker possible?
Old Sep 3, 2009 | 01:15 AM
kris6840's Avatar
I was just wonderin.... Are there any websites that anyone knows.. that sells a Diff Locker... for a 2WD 2002 4Runner? Rear Diff locker at that. Please help me!
Old Sep 3, 2009 | 10:41 AM
brian2sun's Avatar
Your diff is the same as the rear on 4x4 models w/o the elocker. It's referred to as the V6/Turbo 8" diff. ALL '96-02 4runners without the elocker came w/ this diff from the factory (2wd or 4wd).
That means you have your pick of all the same lockers as the 4x4s...ARB, Detroit, Lockright, to name a few. Or you could do an elocker retrofit (there are several write-ups on this on the web).
Old Sep 3, 2009 | 12:21 PM
kris6840's Avatar
Another question
That being said... How would i come about to getting an e-locker?
If anyone knows. I've searched it on the internet and can't seem to find one.
Old Sep 3, 2009 | 12:50 PM
Trail_Banger's Avatar
Rancho Toyota in CA. Those guys are on Yotatech too. I got my E-Locker fomr them. Best price around and it works well.
Old Sep 3, 2009 | 01:07 PM
brian2sun's Avatar
I see them on ebay pretty often. Since you don't have a front diff, you could go w/ your pick of gear ratios. Elockers come in 4.11, 4.30, and 4.56. I would go w/ 4.56 especially if you're running 32" tires or bigger. You'll regain some of the lost power from bigger tires w/ a lower gear ratio. If you have stock size tires and don't plan on going bigger, 4.11 or 4.30s will do fine.
There is a fair bit of modifying that you need to do to retrofit the elocker into your existing diff. Most people do the swap themselves, but if you don't have a welder/grinder you may have to find a shop that would be willing to do it. Or, you could just swap the entire axle w/ one from a junkyard 4runner w/ an elocker already in it which is more $$ upfront, but you'll save on the labor.
Elockers usually go for about $300-500 used and I've seen full elocker equipped axles go for around $700-900 plus shipping. It just comes down to if you want to save time or $$. Here's a link to a good write-up so you can see what the job consists of...
http://www.4runners.org/writeups/elocker/
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
colasurdo
Jul 16, 2015 11:32 AM
