Sponsored by: CARiD
22re no power and a code 25 (lean air fuel mix)
Old Apr 2, 2018 | 10:14 PM
FunkMaster88's Avatar
just had my 22re rebuilt, now I have no power or acceleration ˟˟˟˟ty gas mileage and code 25 lean air fuel mix. Never had this problem before, allllll the sensors have been tested and replaced vacume lines are new and sealed injectors at new, plugs are good you name it only the fuel pump is not replaced cause I’m not having issues with it, it tested fine. Took it to Toyota dealership and they couldn’t figure it out either.
Old Apr 3, 2018 | 07:13 AM
skypilot's Avatar
Your cam is out of time. I bet its retarded by a tooth. Pull the valve cover and roll the engine over by hand till you get the blue link on the mark and then the TDC mark should line up (once every two rotations. Also run the valves lash should be .008 on the intake. You did not mention if you camshaft was replaced, it may have been wiped out before you started. Modern oils suck at solid lifter cams. So truth be told, you have to pull the front and top off to check. You did not state where the parts came from or much detail but your build is off, I hope you did not bend a valve.
olharleyman
Apr 8, 2024 01:48 PM
suckbaby
Feb 19, 2015 08:47 AM
toomster
Apr 8, 2009 01:21 PM
weakyota91
May 28, 2007 11:03 AM
Saint_Berzerker
Mar 28, 2006 07:08 AM
