Sponsored by: CARiD
22re high idle and pushing out coolant after shutoff
Old Jan 21, 2013 | 04:41 PM
jlowery0209's Avatar
i have a 89 toyota 4cyl 5 speed. i replaced the motor about 40,000 miles ago and had no problems until about ten thousand miles ainto the overflow tank go. it started out by idle surging however i fixed this by changing out the iacv. it ran perfect for about two more days and now it is idling high after warm up for about ten or fifteen min and then it will stop and wont do it again until the truck is shut off and cooled down and started again. it is also pushing coolant out after i shut it off into the overflow tank and out the hose. its not running hot though. the heat hand will raise to about half way while it is idling high but after that it comes back down. the tps, iacv,mass air,temp sensor,fan clutch,radiator,throttle body, radiater cap, thermostat,and heat hand are all new. the tps and idle are set right and the timing was double checked.i have also checked for vacume leaks. any ideas?
Old Jan 26, 2013 | 04:52 PM
85celicagthatchback's Avatar
Blown.head gaskit
Old Jan 26, 2013 | 08:55 PM
is that about the only thing it could be as far as internal?
Old Jan 27, 2013 | 09:23 PM
Only one I can think of pull the plug see if water comes out. See if the ager level is slow. Get a pressure tester see if water comes out a cylinder then. Or maybe the intake gaskit. Hook a vaccume gague to it and do a compression.test
Old Jan 28, 2013 | 09:44 AM
the compression test showed about 90 on all the cylinders
Old Jan 28, 2013 | 09:48 AM
is it using water?
Old Jan 29, 2013 | 10:27 AM
i tore the motor down and it had a blown head gasket
Old Jan 29, 2013 | 11:27 AM
that sucks bro. but befor u reassemble it get the head checked and surfaced and a vavle job. but by the point off having the head off its best to pull the whole engine and rebuild it ur self if u can do a valve adjustment ur self u can build a 22re. if u need engine specs i can help u with that
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
ryerye13
Jul 14, 2015 08:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
