Sponsored by: CARiD
2002 Toyota Sequoia Overheating when idle
Old May 30, 2012 | 04:17 PM
teeds01's Avatar
I have a 2002 Toyota Sequoia Limited that is overheating when it's running slow or idling. It starts to heat up slowly - not overheating right away. My mechanic is tell me it's a failing head gasket, but he didn't run any diagnostics. Any input?
Old May 30, 2012 | 06:00 PM
rworegon's Avatar
It could be as simple as needing a new radiator cap. How many miles since the water pump/thermostat last changed? Coolant level ok? Any external leaks?
Do you have any of the classic head gasket failure symptoms: billowing white exhaust, boiling coolant escaping the radiator/overflow, oil in radiator, coolant in oil, bad idle, etc.?
Also, do a search here for testing the fan clutch.
Old May 31, 2012 | 09:21 AM
ZUK's Avatar
ZUK
Does kinda sound like the fan clutch if it's happening at slow speed.
Old May 28, 2015 | 12:39 PM
wyndes@earthlink.net's Avatar
fan clutch
Isn't it the case that all one had to do is crank car with hood open and see if the fan is running
Old Jun 1, 2015 | 09:52 AM
Alaskan91's Avatar
Flush for starters
I had same problem with 91 4Runner 3.0 I flushed the radiator,and installed a new thermostat,not that this was part of the issue I replaced the hoses as well being as they were a bit thin,and I had the coolant system already drained.I added a decent coolant,hint not the 50/50 type.Problem fixed.This is also a good time to check your belts for cracks,and replace as needed.Good luck out there.
Team420
Jan 12, 2021 04:57 PM
vasinvictor
Jan 20, 2016 12:39 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
