1999 4Runner Suspension questions
Alright, I have been to a few places and cant figure out the suspension. I checked out the stickies still couldnt get an answer. So ill just lay out my questions hopefully yall can help me out. Im Looking for some new shocks to replace the OEM ones. I dont need a lift. but if i do....
Alright So i need new Shocks I have no idea which ones to get. Im kinda on a budget i was looking at some Gabriel shocks but they only have them for the rear.
1. Is there shocks i can buy that i can use for all 4 tires?
or do you HAVE to buy seperate shocks for the front and rear?
2. Like the Rancho RS5000 Or can i only use those for the Rear?
All i need is new shocks for right now. Just some replacement for the OEM Ones maybe a step up in performance since i do plan on off roading.
3. If i wanted a lift later on down the road would i just buy coils?
**4. Could i buy the Pro Comp ES 3000 and be fine installing those on all 4 wheels?
if you do decide to lift your best bet is going with some coilovers. if you decide to go the shock/spring as i did (several years ago) you will need:
front shocks
front springs
rear shocks
rear springs
differential drop
spacers for front
and then possibly extended brake lines.
oh and im not endorsing but here is some idea of the different shock/springs plus combos you can do:
http://www.toyteclifts.com/index.php...d=71&Itemid=72
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
cyclist231
Jul 7, 2015 12:56 PM
Vargntucson
Jul 4, 2015 12:15 PM
