Sponsored by: CARiD
1994 pickup blower motor
Old Sep 10, 2017 | 05:11 PM
Gary Dragoo's Avatar
I have 1994 4x4 pickup. The blower motor stopped abruptly while running the A/C. the motor stopped and the a/c is out. The fuses under the glove box are all good and I replaced the relay. If I jump the terminals in the relay plug everything works fine including the fan switch. I am not getting power to the activation part of the relay. Am I missing a fuse somewhere? Where does that power source come from?
Old Sep 11, 2017 | 11:44 AM
Kolton5543's Avatar
Sounds like either the control panel or the A/C amplifier burned out
Old Sep 11, 2017 | 02:56 PM
dropzone's Avatar
Fossilized
Check the blower motor resistor
Old Sep 11, 2017 | 11:22 PM
wyoming9's Avatar
Red face
Just how did you jump the relay that is the question??
Get the correct relay ?? Did you test prior to installing??
You have voltage to the coil and you have voltage on one side of the contacts
If you jumped the contacts it will turn on the blower motor
The 40 amp fuse is most often on the right side near the Circuit Opening Relay if that was open doubtful the 10 amp gauge fuse that powers the coil side would start the blower motor
Old Sep 13, 2017 | 10:43 PM
Turns out that the power for the relay comes off fuse marked gauges. Problem solved!
Old Sep 13, 2017 | 10:46 PM
Had power to the switch part of the relay but not to the terminal that activates the relay.
Old Sep 14, 2017 | 12:34 AM
wyoming9's Avatar
Red face
I have no clue what your trying to say!!!
