1993 4RUNNER keeps blowing 10 amp AC Fuse
#41
Dalgozy, since it is all apart take the extra few minutes to inspect the blower switch and resistor also please.
#42
Yep, time to disconnect battery and start cutting into the loom! Wish I could drop it down further to get at it easier and I pray very deeply I don't have to go into the loom through the firewall! If thats the case, I may decide to do the generic toggle switch to condensor fan and ac clutch. Although I've always believed in fixing things correctly and not rigging them...... If I do have to do the toggle idea, what would be the best switched position place to tap into for power? Bad thing is I used to be a electronics tech and used to read television schematics with a breeze. Now I'm on so many meds for my health, I just cant concentrate and read the most simplest one unless it's on how to wire a table lamp!!! I'll keep you posted with results! Thank you for everything so far!
#44
Strange, because if thats the case the wire that is way overheated is the ground on the front heater relay though Its operating just fine.so what is causing ac fuse to blow instantly when fan control is turned on when ac switch is in the on or off posision and/or when ac switch is unplugged and everything ac wise is disconnected under dash?????
An open resistor won't blow a fuse but a bad one with too much resistance can. You could turn your fan switch to full speed and then replace the fuse to see if it blows. There should be little to no resistance from the resistor on high speed. If it doesn't blow the fuse on high speed but does at any of the other speeds then the resistor should be replaced. On most vehicles it in screwed into the air duct right beside the fan somewhere. Normally held in by two screws.
#45
Yes to all the questions above and I will try the idea of fan on high then putting in fuse. Thanks for that information! And the fuse blows with all of the ac plugs disconnected and switch not even connected.
#46
Heater blower works in all ranges.
The AC fuse blows regardless of AC switch position.
AC fuse also blows with the AC on/off switch and AC sub harness disconnected.
Directly powering the AC compressor clutch provides cold air with AC sub harness and AC on/off switch disconnected.
I think he needs to retest the AC activation wire for shorts to ground. maybe that got skipped? That was about the time we got sidetracked over the AC switch having a backlight.
Dalgozy, run each of these tests give answers in the form of
Test#, "Xyz ohms" or "Open circuit (no continuity)"
AC fuse pin 2, clip a probe lead to it.
using the other lead connect to each test point.
Test1, to body (ground).
Test2, to A14 pin6.
Test3, to ig1 pin9.
Move the first probe lead to A14 pin 6.
Test4, to body (ground).
Test5, to IG1 pin 9.
Move the first probe lead to IG1 pin 9
Test6, to body (ground)
#48
I'm going to have to bow out on this one until I know whether or not the fan works after the fuse blows. He just answered yes to "Does the fan not work at all?". I think it's just a communication issue because I was under the assumption as well, that the entire heater system was working fine. Just not the AC. I was starting to think that there is an open gate between the higher amperage heater system and the 10A AC circuit but not enough information to proceed. I'll check back later.
#49
#50
The heater/ac blower fan works fine in all speeds. The ac 10 amp fuse in kick panel blows instantly with entire ac system unplugged including ac on/off switch. The blower/fan motor continues to work fine in all speeds after fuse blows. Hope that helps!
#54
Test2, to A14 pin6.
Test3, to ig1 pin9.
Test2, to A14 pin6.
Test3, to ig1 pin9.
#55
From fuse box to AC switch, AC Dual Pressure Switch, or to AC cut relay. It branches out to these three components before it goes anywhere else. I have never had a second generation 4Runner so others will have to help us out with the locations of the components. L-W wire in the diagram.
What color is L? Looks blue in the diagram but that doesn't always mean what color it actually is.
#58
Actually before any tests, I need to follow heater ground that is practically raw into the harness to be sure its not shorting any other wires. Then replace the ground wire and if I still have a problem, Then begin all the testes. Doing any tests before being sure burned and melted heater ground wire is not shorted to another wire, is wasting time and effort. I will cut into loom and follow it out and let you all know the results in the next few days. Thanks for all the help and info.
#59
You shouldn't even have hooked the battery back up untill and unless instructed to. Like I said above you aren't just risking danger to you but first responders, people around you, and MY loved ones.
i was being dramatic before when I said the "my loved ones" but now I'm pissed you didn't listen because my brother his wife and children live IN Galveston!!! And she is an EMT!
