Sponsored by: CARiD
1991 4runner replacing water pump and p/s pump and am stuck
Old Mar 30, 2013 | 03:06 PM
Bshulman's Avatar
Started pulling off all of the required parts to remove water pump and am now stuck. Cannot remove the plastic cover over water pump. Also, looks like I will need to remove timing belt. What's the best course off action?
Old Mar 30, 2013 | 04:02 PM
a51young's Avatar
The fsm has a nice walk through and there are other pictorial guides here. I did the water pump a few weeks ago.
I think the cover you're talking about is the timing belt cover, there are a few boltd under them speak plug wires and a few visable around the cover
Fsm:
http://web.archive.org/web/200808020...5/contents.htm
Old Mar 30, 2013 | 04:08 PM
a51young's Avatar
Assuming 3vze since you mention timing belt
http://web.archive.org/web/200807310...e/timingbe.pdf
Once that's taken off you can get to the water pump
http://web.archive.org/web/200807310...s/waterpum.pdf
Old Apr 3, 2013 | 11:27 AM
Hummer96's Avatar
Agreed. Water pipe, timing covers, timing belt, etc. have to be removed before you can get to the water pump. Depending on how many miles are on your belt, it might be a good idea to replace the belt, idlers, etc. while you're right there.
-Aaron
zd92655
Mar 6, 2022 12:58 PM
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
deuxdiesel
Jun 20, 2015 02:49 PM
infinityisfive
Jun 16, 2015 06:51 PM
