1991 4Runner question
Hi, I am relatively new here, last year I bought a 1991 4runner 4wd, with the 3vz engine, manual transmission, 320,000 miles, it has good compression, I just changed the timing belt, water pump, all front belts, alternator, oil, battery, and currently I am fabricating replacement patches for some rust on the rear wheel wells, my frame is in good shape ( Colorado pampered), but I can not find the name from some six rubber "dampener/attachment" "things" that are between the frame and the chassis, which hold the frame to the chassis with six hardened bolts and an oversized washer, they are badly worn out and I fear it may be a problem in the making if I don't replace them soon, so I need the name to buy them at my local O'reilly; bear with me, English is my second language, and I work on Aircraft ( I flew for ten years before learning how to drive a car...so I am a newbie about cars). Can you help me with the name? ( It's not a joke)
http://www.4crawler.com/4x4/ForSale/...ft.shtml#GenII
try this place for the "Body Mount Bushings" looks to run around $100. I have this lift and bushings, easy install, great place to do business.
Many thanks!...I just ordered them, also a new set of rear springs, that the ones I have have sagged two inches...
When I finish with this puppy...it may have a diesel engine, make 50 miles per gallon, and would require an FAA permit to drive it..hehehe
TURBOrunnerNM
Jul 22, 2015 11:01 AM
